Will they rub?
westsidecalifas707
I just got a hold of some rims but haven't put them in my truck because I'm not sure if they will rub I have a 2013 Silverado 1500 crewcab 2wd the rims I got are u2 55 size 26 tires size is
275 25zr 26
Will it rub? Any advice or thoughts are greatly appreciated thanks in advance - Jordan
depends on the offset. GM stock rim offset is +30mm.
  • 5 weeks later...
Thanks and I ended up finding out that they rubbed so I took it to a shop to fix it here's what it looks like though e5fdd1173373a5ec232de13d4e3e3597.jpg
I know it a super late reply but I've been busy to say the least thanks everyone
They're u2-55 and yeah it's not as much rubber as I wanted but I ended up going with 305-30zr-26 tires I had a shop cut the plastic and metal plate so they wouldn't rub
  • 1 year later...
I currently am all stock on my 2013 Chevy Silverado v8 2wd single cab. NO LEVEL INSTALLED 245/70/17. I bought some 18" wheels and 275/65/18 all terrains. will they rub? I'm trying to avoid a leveling kit until next month. $$001.jpg
My old man runs 275/65/18 on his '08 Silverado 4x4 without a level and no rub. The 2wd and 4wd stock heights are pretty much identical so you should be ok. Only issue would be if they are aftermarket wheels and have a different offset than factory, which could cause them to rub.
