4wd problem
Hey everyone. I have a 2000 silverado 2500 with electronic 4wd. I've replaced the actuator, and just replaced the 4wd dash control. Still my service 4wd light is on, the light for 4 hi 4lo and 2wd doesn't light up anymore and there's no noise from the actuator. What could be the problem?
There is a code in the TCCM to be pulled ,
You have to get it scanned by a scanner that is capable to pull them
Stop guessing
Yes, get it scanned and find out before it leaves you broken down on the road. My 2006 Sierra was doing that and I ignored it until the transfer case grenaded, but I was only 1.3miles from home and managed to limp it in. The transfer case oil was full of metal chunks as well as the bad encoder motor.
