I have a 96' s10 blazer Lt.  The driver power seat quit working along with the power lumber on both sides.  I checked the 20 amp fuse and it works because the power locks and rke are in the same fuse and they work.  any help is appericated.
Thanks Dave
It sounds like a power distribution problem since it affected both seats, using a test light see if you have power in the switch panel for the driver's seat, if no power is present it is a problem between the seat and the fuse panel, maybe a bad connection, loose connector, also check the other breakers to be sure there isn't an additional breaker to power the seat, sometimes the supply will be on one circuit and the control switch for the relay will be on a different breaker.
