Roof Rails
Hi,
Does anyone know how to remove the roof rails on a '15 Suburban ? I damaged my roof rails in a parking lot, and need to replace it.
The screws which holds the rails in place seems to accessible only from the bottom, and not from the top. I hope I don't have to rip out the interior ceiling to access the fastening screws.....
Any ideas ?
Thank you & appreciated.
RM
stereopal - dealerships have a shop manual, call around to a few service departments and ask the question. Don't stop until one of them tell you what you want to hear
  • 9 months later...
