2015 Tahoe Mirrors on 2014 Silverado
07Softail
I'm not sure if they fit, but they probably do. The Tahoe LTZ has blind-spot alerts, and I have no idea if that feature can be activated in a truck.
Not sure if blind spot can be added and transmit the alert to the Tahoe mirrors, but blind spot alert CAN be added to our trucks as a stand alone. I'm actually in the process of doing it. Hardware is ~$350, add a few more hundred for labor (which is what I'm shopping around for)
Really? How so?
Really? How so?
All it is, is a GPS equipped module that functions much like the front and rear parking sensors. Once something moves into a predetermined radius, it sends a signal to a light, monitor or what have you so. The reason it's GPS equipped is so that you don't get false alerts or readings when traveling under 15MPH (I think. Could be a higher millage)
Here's a link to the one I have. Like I said, I'm just shopping around for labor.
http://www.goshers.com/premium-blind-spot-detection-system-bsds-003016p/
Ok, bro- I'm done hijacking your thread. Sorry.
do you have any pics of the mirrors? I can't find any online
Edit**
Some how I thought this was about their tow mirrors. Never mind if it is the basic mirrors.
I saw a New Tahoe today and noticed the Mirrors are smaller and look a lot better to me. Will this swap work...has anyone done this?
RT
I ordered mine with the NHT option because I thought the regular mirrors were too small lol
RT
I think you would be the guinea pig lol. The doors are different between the two trucks, as are the mirrors. The question is if they mount the same (the same mirror to door base, and same door mounting area).
I am going to a check them both out at a dealership saturday and will get back. I don't really care about all the bells and whistles I just like the shape of them...they look more sporty to me.
RT
