Blue smoke on start up
seansharley
I noticed this on my '09 5.3, now I'm seeing it on my '14 6.2. As the truck gets close to being due for service (4-5,000) miles, when I remote start it, I see a puff of blue smoke. My '09 had 80,000 on the clock when I traded it, my '14 now has 25,000 on it. Anyone else noticing this?
Yep - my '07 has been doing that since around 20k miles. Welcome to 21st century manufacturing practices .... :banghead:
