Part # for 6.2 PCV Tube??
Last C5
It was easy enough to come up with the part numbers for my clean side pcv tubes (valve cover to air box) on the 6.2 but I can't find the part number for the main pcv tube (valley to rear of throttle body) Anybody know what it is??
Also, if I catch can the clean side should I consider connecting the valve cover to the inlet side of the catch can or the outlet. I know is supposed to be the clean air return to the valve cover but my other LS engines have pumped a lot of oil out of those valve cover outlets and I don't see why this one would be any different.
I ordered one from my dealer for my catch can install so I had a back up. I also have the 6.2. My parts guy was able to find it under PCV dirty. I just threw away the box with the number sorry! I do know with a 15% discount it was around $25.00.
Thanks, at least I'll have a better chance of getting one if I know where to have them look. Appreciate the reply. :thumbs:
Got my tube so I can use the ends for a little cleaner catch can install.
The Part # is 12650610
Exactly what I did.....
  • 1 month later...
  • 3 years later...
    President Roberto
    President Roberto
  • Who's Online   0 Members, 0 Anonymous, 158 Guests (See full list)
