Future truck engine RPO's
THere are rumors, but no one, not even dealers know RPO codes until GM releases build specs/sheets for the vehicle in order to order them.
As to the V-10/Big Block thing, GM WILL NOT be using a V-10 anytime in the near future.  They considered and spent some R&D on a V-10 prior to the intro of the Vortec 8100 and came to the conclusion that the R&D, cost of engineering, tooling of engine factory's (such as Tonawanda where the 8.1 is built), re-training service technicians, cost of replacement parts VS. the power output and fuel efficiency of a much simpler and well known BBC design wasn't worth the cost to bring it to market.
As is, the BBC wallops the V-10's from the competition in terms of power, equals or betters them in fuel mileage (I know, I know), and does it in a much more easily servicable, cost efficient, smoother running (due to "even firing" for each cylinder vs. a V-10 with "semi-even firing" measured in degrees), and from an engineering standpoint, much simpler powerplant.  As is currently, the 8.1 is rather conservatively setup from the factory with a relatively low compression ratio and stout bottom end which is the hallmark of BBC's.  SO there is PLENTY of room for improvement should the competition TRY to fight GM Powertrain for big gas engine bragging rights.  A fight, neither will win very easily.
Why go V-10?  :chevy:
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
    • Move further away.   Benefit of living out - none of our cars get short cycled, plenty of warm up time.   Curious how much time/temperature it takes to drive moisture/condensation out of the engine?
    • Switch a a 100% synthetic trans fluid, Amsoil works for me.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
