Im finally here!
JHall396
Hello everyone,
My name is Jim. I live in Euless Texas (the Metroplex between Dallas & Ft Worth). I currently drive a 2011 Texas Edition Ext Cab that I'm slooooowly adding stuff to. (emphasis on slow cause that's how funds roll in to my bank account LOL)
Glad to be here, searched the pages / articles yesterday, very informative and awesome stuff here.
Ill be asking questions and commenting on the awesome GM pics...well from now on! :-)
Thank you again
Jim
This is definitely not the place to search around for ideas for "stuff" to add if you're wanting to save money!! :D
Welcome to the site!
Yeah I kinda noticed that LOL
Thanks :rollin:
Welcome from East Texas!
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 986 Guests (See full list)
