4x4 fabtech issues? 4" lift
so i have a 2015 chevy silverado1500 z71 ltz with ranchos all around....i got a fabtech 4" lift, budget lift, like 900$....with fabtech shocks in the rear...when i put it into 4x4 and i try to turn sharply it feels like theres a rubbing or something? its so fn stiff! like its not suppose to act like this....any thoughts? please help...60,00$ truck >.<
Sounds normal. When you turn sharply in 4 wheel drive, your front tires are rotating at different speeds but your front diff wants to turn them at the same rate so that creates a conflict.
Unless you're saying your tires are rubbing. You should be able to see if they're scrubbing something.
60,00$ truck
Your $60k deserves better than that.
local company
Did the install come with some sort of coverage I would ask, secondly this is my first time hearing a fab tech issue
if you have the stock rims 18 in or 17 it will be rubbing u need an offset rim
  • Use 33/12.50R17 tire w/ 17x8 wheels w/ 4 1/2” BS w/ minor trimming
  • Use 275/65R18 tire w/ 18x8 wheels w/ 4 1/2” BS w/ minor trimming
  • Use 295/55R20 tire w/ 20x9 wheels w/ 5” BS w/ minor trimming
i have the fabtech 4 in have 18 in rims with a zero offset they even rub when backing up and the wheel cranked all the way rubs on the 'carpet' fender well they should have replaced the upper control arm and if they did that look at the rim inside its probably rubbing on that i tried a stock 17 rim for winter it hit the control arm
try not being in 4x4 if pavement is dry it will be hard to turn if it does that in 2 wheel drive then u havr an issue
Okay So apparently the place i brought it to looked under the front and noticed both struts were going and fabtech is looking for a solution ? >.< oH DEAR.
yes i have a off set 33/12.50R18 i think....umm but yeah ur correct about the 4x4 turning issues on dry pavement, it seriously sounds so horrible like your about to break something >.< in 2 wheel, its fine . i had a ram and 4x4 on dry never had this issue ? but it was not lifted or anything and with 285s for tires....not used to this yet just scared is all ! but thankyouu for the intel.
Don't drive in 4x4 on dry pavement.
ya ihad mine in 4x4 yesterday after i came off some snow brutal on dry pavement can barely turn it no turning radius at all was wtf ...then duh switched to 2 wheel and smooth sailing
yeah honestly didnt have that issue on my ram, just new to this new truck so kinda figuring things out, def a eye opener.
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
    • Yeah, shame I can’t really get that filter easily anymore. Running a PureOne. Your fave!    TAN would be neat to see. Confirmation I ran it too long probably. 🤣
    • My son and I both bought new trucks in 2017. Both of us immediately put Truck Covers USA American Roll Covers on our trucks. My son still has his truck and it never sees the inside of a garage. We live in Alabama, so not much snow. My truck was my daily driver and was in the garage when I wasn't driving it or at work. No issues with either cover even after almost 9 years. About a year ago I sold my truck to my brother and bought a 2025 Silverado 2500. The second thing that I put on that truck was a new Truck Covers USA cover. They are very well made and have a very positive locking system. I looked at a Retrax and my concern was the way that the cover locked to the rail. BTW, the first thing I put on the new truck was step bars. Those new trucks are high!
    • The Allison 10 speed torque converter doesn't "lock up" like the previous transmissions. It has 4 operational modes; open, slip, transition from open to slip; transition from slip to open. I have an Edge CTS3 monitor and I monitor transmission torque converter slip. Step on the gas and you get a little slip. Take your foot off the gas and you get a little negative slip. I have not found a way to display the torque converter mode beyond that. My Edge CTS3 also displays something that our trucks should already display, the current gear. I also monitor throttle body position and engine load. If I see the engine load getting too high, I'll manually drop a gear.
    • Nice result. Your filter is working well  I'd have like to have seen the acid number for this sample. Curious type that I am.
