2015 Silverado 4.3 Exhaust and 0-100mph video.
Gorske
It's pretty ridiculous how some people try to paint the new 4.3l as "painfully slow" when it's as fast as previous gen V8s, and at most only a second slower 0-60 than the current 5.3l.
I hope you understand I wasn't saying that the 4.3 is painfully slow, I own one, and enjoy driving it a lot. I was just simply stating that I have driven the new 5.3 and compared to my truck, I didn't feel that it was leaps and bounds ahead of my 4.3
  • Replies 34
I understand, to me it seemed like your post agreed with me.
I was speaking more to the strange phenomenon I've encountered on this board of any time someone posts something about their 4.3l truck, some feel compelled to mock them like they are driving a GEO Metro 3 cylinder with a 25 second 0-60 time.
The new 4.3l has about the same power (in some case more) as the 4.8l/5.3l/5.6l V8s we've all been driving for the last 30 years.
The fact the new 5.3l has a bit more hp/torque than it used to doesn't make that level of power "horrendously unusable" suddenly, I've been pretty happy with our GM trucks from the 70s up until my last 2010. Towed a lot of fishing boats, hauled a lot of crap.
I don't get it personally. I can afford any truck GM builds, and I bought a pretty loaded 4.3l 2014 Silverado because it met my needs except for one. (and was pretty much the same as driving my 2010 5.3l) The only reason I don't still own it is the dealer told me there was no transmission cooler for it and they would void my warranty if I had an aftermarket put on it.
I'm old school and don't care if the new transmission fluids are safe to higher heat levels, I want an external cooler on a pickup. So I bought a 2015 5.3l.
I "could" have bought a 6.2 or a Duramax, but the money I didn't spend on power I don't need to tow my 2500lb boat I can blow on other stuff.
Assuming that video was with the truck on the road and not with the rear tires jacked, I was impressed. Looked like 0-60 was in the 6 second range.
I'll admit when I consider buying a truck, the V6 engine would be last thing on my list of options for it. Well, besides some type of turbo system... I say, the 4.3 is impressive and I can see how it handle most of 1/2 ton owners needs. Today, I'd still opt for a V8 just for the simple fact of resell. Same reason I wouldn't buy a gas HD truck.
I am impressed with the 4.3 and saving the 6,000 dollars was hard to pass up but I do miss the sound of a V8. For now I will get the most out of this 4.3 and see what kind of power and numbers I can get out of it. Then in a couple years switch up to a Double Cab 4x4 with a 5.3
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
