6.2 Gas Truck
kilbornf
Looking for your OPINION.Have a 2011 6.2 liter gas truck Slverado 4*4.Bought truck brand new has run perfect since new.Has about 110,000k on it now and have noticed it starting to use oil.3100k and 1 liter of oil to bring to full mark.I think the motor is starting to get loose inside.Oil pressure use to run at the 5 on the gauge of the 275kpa mark,now it is at the 2.Truck has had gm oil changes since day 1 and DEALER changes it between 7500/10000k.Seems to have started this since the last oil change but oil could have been down some on last oil change.I wonder what GM will say?
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
