Hello All;
I have a 2004, 5.3L, about 135K.
Here's what I know. Relitavly new battery, tested with a meter, off: 12.43, running w/bat. light and message(1):~12.4 / running wo/bat. light or message(2) ~14.5.
Step son has been driving for about 5 months. It had been parked for about a year before that. He comes home last night and says the light is on (and Oh, BTW, it has been on for about 2 weeks), Now the message center display says it's not charging. I didn't test it last night because it was raining. Checked this morning and no light or message. Shut it off and checked the battery, ~12.43V. Started it up, again no light, no messsage, tested at about 14.5V. While letting the truck idle, I read a few postings on here and fiddled with the plug to make sure it was getting a good conection. Checked the connections at the battery terminals and the ground could have been tighter. So I shut it off (it had been running for about a half hour still with no light, no message, and about 13.2V on the meter. I wire brushed the terminals and tightened. Started it up and now I have the light and the 'Battery Not Charging' message again. Checked it with the meter again and it's NOT charging. I let it sit for about and hour, but it's still hot and the light and message are still there and it's definatly not charging.
I'll check again when it's completly cold and see if this cycle repeats.
Is there something that could work when it's cold and then not work when i's hot? I don't just want to replace parts for no reason if i can pin point the problem.
Any thoughts or suggestions?
Thanks,
We had a Chevy V8 sit for a year and then started using it again, for the first few weeks it was fine, then one night a 30 miinute trip killed the Alternator, We had headlights, and heater running
I replaced the Alternator and it was fine after that
There is not nuch to the Chevy charging system, everything is inside the Alternator, as long as the heavy red wire is connected to the battery and Alternator and the little plug is in that's it
Mine smelled a little burnt, and the windings looked funny
It may be heating up and then failing to charge
Being a Chevy guy, If its not the battery its the Alternator
Good Luck and let us know
Joe
PS the NCC-74656 kicks the NCC-1701's ASS .....
Joe
Joe,
Thanks for the reply. I'll wait until the end of the day to see if anyone else has any differing opinions before going for the alternator.
As for the NCC's, I couldn't agree more. I only defer to the 1701 because that got it all started (and i saw the originals before reruns), but I agree, Janeway and the crew kick ass.
I had to look up what the heck you 2 were talking about....I'm not of that generation apparently!
I would get your alternator tested, and then be ready to replace it. That sounds similar to mine. It went on for a couple weeks of sometimes working and sometimes not. Since then, solid 14+ volts all day now!
I would also check your battery, you never know. I just had a battery with a bad cell and would cause the door chime to go off without the key! Really weird symptoms, but new battery solved all of that as well.
Edited by sahls01gmc
Make sure you let us know !!
I only say the NCC-74656 is better because of the BORG tech mod for Trans-Warp LOL :)
Yep, replaced the alternator in about a 45 minutes, no light, no message and guage reads ~14.2. I didn't bother with any further testing.
Thanks guys for your input.
Looks like I'm done here. Beam me up Scotty........ :D
That's GREAT!!
Live Long and Prosper :)
Hello again all,
Just as a follow up and an FYI:
Alternator still working fine with no electricial issues.
The FYI part is that about 2.5 - 3 months ago the engin light came on and neither Auto Zone nor O'Reilly could tell why. I still don't know why and I don't know if this is even related, but a few days after changing the alternator it went out. Who knows? ? ? Maybe a coninsidence, maybe not.
I've never had a GM alternator last 100K without failing in some way. Been that way since my first GM with an alternator in 1969.
My 1998 K1500 alternator didn't even last 30K and the 2002 Yukon about 50K.
Edited by waumo1
  • 5 years later...
my 2000 Yukon is just now going out 20yrs and 250k
    • I’m out of ideas on this truck. 2020 Silverado 1500. 5.3 135,000 miles. Has a p0308 and p050d codes. Smokes From exhaust when cold. Compression test passed. New plugs, wires and coil on cyl 8. Same issue. New coil on 8, no change. Replaced injectors, no change. Bore scope showed oil pooled on the piston after sitting overnight. Pulled head and had machine shop check it out. No cracks. Stem seals looked good, replaced anyways. He also ground valve seats. Put it all back together and still have the same issue. Bore scope shows oil on the piston again. Leaning towards maybe a cracked ring but unsure. Cylinder looked good when the head was off, no scoring or scratches. Any ideas on what else I should look for?  Appreciate the help
    • Just want to make sure it is covered by Special Coverage N232395310 Evaporative Emission Purge Pump 2021 Silverado 1500 Custom 2.7L L3B ~100k miles I'm getting DTCs P146B and P146F. VIN 3GCPWBEK2MGxxxxxx   I spoke to a person that works at GM and he said it is not covered after checking my VIN.   Is there anyone here who currently works for a GM/Chevrolet dealership and has access to GM Global Warranty Management / Investigate Vehicle History who could explain how the VIN eligibility is determined?   thank you
    • Thanks for all that information, I might purchase one and see if it will work for me, if not they may let me return it! Yes for sure the tires are definitely within limit for my truck empty, and when I do tow I'll definitely make sure to raise the rear psi for the amount of weight that's going to be on it.
    • Yes exactly, more and more these days people/companies are afraid of liability issues so its easier just to say no rather than risk putting their neck on the line.    I will say with the Autel unit or when I used it last year on my truck, it wasn't like I could choose the 2025 model year or even the 2024 model year as that option was not there to manipulate the placard pressures but had to go back to 2023 or there abouts and then it showed up as an option, odd but that was how the software was then and I can't say one way or the other now as they throw out updates every so often. I still would talk to your tire dealer though to start with and they may do it for nothing but also they may have a comment on a better unit to purchase. All I know is that one of the large tire shops in my area happens to use these Autel units for their use and set them up to use the wifi and all of that jazz for constant updating because each tire tech has one handed to them by the shop but I just plugged it into my laptop to update it and yes if one is bought it has to be registered so you can get the link to do updates and then the unit has to be updated before its even used. I am not at all techy so it took me a bit but anyway just a heads up for anything you buy, most likely it will need to be connected to a computer to access the internet to have it updated to the latest software version before you can put it to use.   If your truck is near empty, those tire pressures you listed are a very safe upper range pressures to carry the weight, both the front and rear as I know they could be run lower yet with an empty truck. And if its a trailer and not some motorcycle your going to strap onto the front of your truck on a rack, you shouldn't have a need to inflate your front tires if your at 55 front already, its the rear ones that would need more air if you have much hitch weight.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
