How to address rear main leak?
So had my trans rebuilt about 3 months ago and last month i noticed oil in my drive and i just found its coming from the bell housing and it appears to be the rear main. This truck has never had a leak in there as long as i've owned it and I'm thinking they may have damaged it while taking the trans out or installing it. I have a 3yr/50K warranty on the trans and only the transmission shop can service or touch the trans to keep the warranty (i've put 400 miles on since the rebuild) how do i address this, i cant believe its never leaked before but now its all over the place. Really don't wanna pay the trans shop 1K to repair this
I would sooner suspect the oil cooler adapter or oil pressure sensor, though off the top of my head I don't remember where the sensor is.
Thanks i'll check those out tomorrow
I'd try to confirm exactly where it is leaking from and go from there. With my current truck I had oil, dirt, and sludge all over the place so I had to start out with just cleaning the engine the best I could to even start figuring out where the oil was coming from. Got one leak fixed (oil cooler lines) but I have at least one more, but hopefully I've slowed it down a bit.
  • 4 weeks later...
Don't rule out oil pan. I've done a hundred more oil pans than rear main seals. Pull the viewing plate on bell housing rotate engine so u can see through hole on flex plate see if u can see rear main leaking. Usually its back of oil pan
It tuned out to be the front axle seal, oil cooler gasket, and rear main. I also have a very small pan gasket leak but they wouldnt repair it because they aren't a repair shop
Ummm...what, sorry? This "shop" just confused me.
It was a trans shop who fixed the rear main, tcase leak and the front axle seal. they said because they weren't a "repair shop" they wouldn't do the oil pan.
No, you have to pull the transmission. At least that's what 2 different shops have confirmed with me.
    BigJake
    BigJake
  • Who's Online   4 Members, 0 Anonymous, 652 Guests (See full list)
