2005 Yukon Denali Air suspension
Hardy52
I have a 2005 Yukon Denali. I have replaced the rear air shocks and the suspension compressor. The compressor turns on and the passenger air shock fills and the pump stops pumping, but the driver side shock does not fill. I have switched the shocks around to make sure that both shocks are good and the drivers side still does not pump up. What should I check next?
