GMC CURT Brake Controller Package
Looks Ok, for just a few $'s more you can go to your local RV dealer and pick up a Prodigy 2 or 3 which are much nicer than that Curt
I've got a P3 off my GMT900 I'm about to put up on craigslist if you're interested....awesome controller.
I have the Curt brake controller , I had dealer throw it in to deal , simple plug in and I mounted it tight to the 4 x 4 gear shifter on the tunnel as close to seat as possible while still giving me quick "reach down " and activate when needed . ( just screwed it to carpet) and it has been fine no problems and not in way. Wiring was able to tuck behind bottom of dash with zip ties out of sight . It works the way they all work ...fine !
Near as I can tell the curt triflex controller is the equivalent of the p3. Don't know if it is capable of electric over hydraulic but it seems to be the same.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,002 Guests (See full list)
