Steering Wheel Minor Squeak
On a recent road trip, my steering wheel has a rather annoying minor squeak when making minor road corrections. Sounds like its coming right between the wheel and column. Only happens if I haven't rotated the wheel around in a while, which explains why I don't see it around town. On the road trip, came to a light in a small town, rotated the wheel lock to lock, and squeak was gone for a few miles, then came back. If I was a betting man, I would say rotation keeps grease well distributed, but minor corrections move enough out of the way to cause it to rub on the plastic in one spot.
Anyone else have this? Got it fixed, and have info on what they did to fix it? Looking for info from others that hopefully had it fixed before I meet with GM reps this Friday about my truck.
I have the same problem. Just figured that the dealer won't be able to duplicate the problem since only occurs after driving awhile and during minor steering corrections that you describe. So I'm not going to waste my time on taking it in. I've already had my share of "can't duplicate customers concern ".
Let us know how you come out on this.
Took the truck in this morning for this squeak and another issue. Dealership says they knew what it was, and need to order a new "clockspring". Once the part is put in, I'll update if it solves the issue.
Hey CounterMeasure,
Glad to see that the dealership is working towards a resolution. We look forward to your updates, and are here if you have any additional questions or concerns.
Patsy G
GM Customer Care
  • 1 month later...
Was this ever resolved? if so, how?
Thanks
Thanks
Nope. They changed the clockspring in there, and I took the long way home from the dealership only to have it do it again. I have bigger issues with the truck, so I haven't tried to follow up on that specific point. At this point, I don't expect it to be resolved while I own the vehicle. GM and the dealership keep saying "buyback" while I say "fix" for various issues. At this point, I suspect they just want to sell the truck as pre-owned and hope the next owner doesn't expect as much "precision" or "professional grade".
Im pretty sure I have the same thing as you. VERY minors road corrections (move the wheel 1/4 or 1/2 inch) to make a little rattle or squeak as you put it( pretty faint sound)? I noticed the first time driving on the highways going to the mountains and back, but I've noticed it more of like you said when you don't turn/steer for a while. Sorry to hear you are having more and bigger problems with your truck! to be honest this and one other rattle from the big back seat when it is folded up are the only problems I have had, if you can even call those problems. I am a huge stickler for random noises and rattles in my vehicles obvisouly thats why I looked into it here. I was going to bring it up when I take it in for its first oil change but i may investigate a little myself in the next few days. hopefully i can come back with a solution!
  • 1 year later...
Has anyone found a solution to this issue? I've been hearing the same creek from my steering wheel on minor corrections almost since the day I bought it. I have a 2015 Silverado LT.
Yes. About 8 months ago I had finally had enough, so I went on a drive with the column covering off, which is really easy to remove. Pinpointed the noise to two white plastic parts rubbing on each other. One is a pin that goes into the groove of another, and moves in that groove when you turn the wheel. After a while, the small amount of yellowish grease in that area is pushed to each side when you do minor corrections, resulting in the noise as the plastic rubs. Once you turn the wheel around, you redistribute the grease. I was able to get a bunch more grease up in there on the tip of a screwdriver, and never had the noise again.
Then about 6 months ago, the telescoping feature of the column locked in the outer most position. I couldn't get it to collapse. So they replaced the whole column, and luckily this new one doesn't make the noise.
Hope this helps!
I have the noise, dealer couldn't reproduce customer concern so I have been dealing with it. Mine makes a more pronounced squeak when turning the steering wheel lock to lock, like when in a parking lot. It's annoying as heck and embarrassing when my co workers are in the vehicle with me, but not as bad as when the transmission CLUNKS and lunges forward....
  • 2 months later...
I took my truck to the dealer, explained the situation, and they replaced some parts and there is no more creeking sound.
  • 9 months later...
Hope this helps!
got any pictures?
  • 2 years later...
Did you ever find out what the issue was, I have the same exact problem with me 2015 4Wd Silverado 1500
    • I just can't think of the exact term GM uses for that higher gvw package without looking at the website but basically sort of a trailering package and I imagine it may also have been created to skirt around the licensing fee differences between a3/4 and 1 ton that apply in some states although ironically I believe in some states its the reverse that a 1 ton is the cheaper truck to license over a 3/4 ton. It makes no difference here in Alberta but oddly enough a 1 ton through my insurance company is a bit cheaper to insure over a 3/4 ton as its based on the insurance statistics they generate.    For sure when ever you do have the chance to weigh your truck and to be fair, try to have the fuel tank full or nearly so rather than give yourself a false sense of the truck being lighter by having an almost empty tank.    In my other comment I was mentioning stock sized tires and partly in case someone was reading this and thinking they could lower their pressure down to what your aftermarket tires are able to do with your empty truck as that is a vastly different picture in the leeway you have to play with for running minimum pressures while remaining safe. I will say also that its easy to see from reactions of truck owners that may have been more used to owning a half ton in the past or a car and be it on a forum like this or in person etc that they get so wrapped up in that placard pressure sticker that they can't get their head wrapped around the fact that an HD truck due to how much it can carry can also vary the tire pressures drastically lower than those pressures ( typically more so for the rear axle on stock sized tires ) when empty vs some car that isn't made to carry much so the tire pressures can't be lowered since it needs almost that much pressure just to carry the empty car.    If I ever do find myself in the states with this truck, I will only be too happy to switch it over to the US measuring system as then I will understand all the dash readings. The only thing that is off for me slightly with US measurements is US miles per gallon as I grew up with the Imperial gallon and to this day up here anyway speak in Imperial miles per gallon ( I don't do that on this forum though as that would confuse everyone for no good reason ).
    • Yes that's right, it's the upgrade that includes the overload spring and all that stuff.   Someday when I'm empty and going by a scale I'm going to stop in and get some weight readings.   Exactly  you should have the ability to change individual settings, in in Canada so I'm driving with kph but then I'm stuck with kpa when I want psi lol
    • You must have that upgraded gvw package which is only available or at least was in 2025 with the diesel engine for the 3/4 ton and that gave the truck physically the larger 12.0 ring gear rear diff and the 3500 rear spring pack. There is a difference in what the diff housing looks like externally as one tell tale and also your truck should have the upper overload spring pack and the frame pads that the pack goes up against.    The pressure the tpms system kicks the alarm in on a stock setting truck, that is a good question and was just from what I recall but I doubt I made any notes on it as I knew for the rear that it was not at all what I was after regardless either. Being that you have a diesel and if running on stock tires the minimum pressure on an empty truck seems to be around 50 psi from hearing of those that have weighted the front axle but the rear axle is very similar in weight to a gas truck and again a near empty truck on the rear could go down to 35 pounds at minimum. However the weigh scale is the proper way to know for sure as a guide.    As to changing the readings on the dash from metric to the US measuring system, oh yes that is done easily but what I was attempting to explain was that I can't pick and choose items I want to have in US and those I still want in the metric system at the same time as its either all or none. For example lets say you drove into Canada and switched your dash over to metric so your speedometer read in km an hour, well then your reading kilopascals on your tpms readout and your wife looks over and says what the hell is that saying in the tpms screen and you say "darned if I know, I think its Chinese" !
    • This is partly why I decided to have switched over to Amsoil SS as a way of hopefully preventing the buildup of the sludge/carbon on the pistons and clogging of the oil control rings and the carbon that would cause the compression rings to stick in their grooves as well as stay cleaner up top of the heads in the valve train in the first place, an oil that has tested better by third party testing over typical shelf oil and also doing my best to run relatively short OCI. However in saying that I don't think there is any way to easily prove the oil I was using prior allowed for a buildup at the OCI I was doing, nor in the other direction to make claims the Amsoil is keeping everything clean either. There really isn't a window into the engine is there to know anything for certain even if oil samples were taken for example that showed still healthy oil being dropped out of the oil pan other than engine tear downs that extensive and expensive testing of oils does to actually visually see what is really going on inside the engine. I wish there was some easy method of seeing what is going on but I don't happen to be aware of that if there is.
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
