Any way to re-set the park position of windshield wipers?
My 2002 SD does this weird thing where the wipers go down almost to the cowl and then they bump up about 4 inches to where they rest. To me, it seems like they aren't set in the right position so the parking mechanism is trying to keep them up higher at rest. I honestly don't know much about wiper systems and how they work, but curious if I could loosen the nuts and move the arms to a more ideal spot where the wipers would park in a more ideal spot.
Yes , loose the arms and operate them normally , shut them off and replace the arms parralell to ground obviously .
Tighten the nuts good, I hit them with a 3/8 " impact , works great , but use hand tools and you'll be fine .... Drive truck lol
Will that work if the reason they don't park correctly is due to a bad wiper module?
You can try it or replace the wiper module, I never replaced 1 '02 wiper module
Lots of late 90s thou,,
Are you guessing the module is done or what?
a few years ago in heavy downpour I had wipers on full speed. When I shut them off they park 2 inches above cowl plus they are not smooth anymore, a bit of pulsing. This truck is an '01.
A tech on another forum suggested that it might be a bad module. To me, that sounds like big $$$. I can at least try to loosen the nuts and re-park them. However, I just had my windshield replaced, so I assume they had already taken the wiper arms off and repositioned them. Thus hinting at bad module. :/
So looking up modules... a Dorman one is only $22/sh on Amazon so I'm just going with that. The job looks incredibly easy. Will report back but it seems pretty certain to be that part.
There should be little hash marks on your windshield for where the wipers should be "parked". So I'd take the arms off, run the wipers, turn off and then reattach with the blade placed directly over those little marks.
If the board in the module is bad the wipers still wont park correctly next time they are used.
As an update:
I swapped out the new module and no difference. The wipers still bump up when when they park. I made sure to place them at the hash marks.
To rule out my wiper placement, I tried running the system without wipers on the terminals and noticed that they will go through a full cycle and bump back up a little when they park. Maybe that's just the way they are supposed to be... Doesn't seem right tho. Frustrating..
Possible you got a bad one. For $22 I would not be surprised that they do not test them before packaging. I know the original modules are known for having cold solder joint which sometimes cracks over time. I think that is what happened to mine.
    • I would have to read back to get a better picture in my mind of some of the other comments and what they were using for a driving scenario they based the fuel mileage off of. That is why the fuel mileage conversation is extremely difficult to make fair comparisons from. If I was to be living in town and only driving around town, light to light and some longer stretches that doesn't have a light every block, and the usual stop at a grocery store and the bank and so on and so forth, my fuel mileage even during the summer time would be so bad with my truck I don't even want to know how bad it would be !. Then add in winter time and idling to warm it up to clear the windows and driving through snowy streets etc, large heavy trucks with gas engines have NEVER been worth crap for fuel mileage and why some little pot licker of a car with wheelbarrow tires and a 1300 cc four cylinder non turbo engine was the ticket to using a mere fraction of the fuel over a full size pickup.    By the way my truck has the 34" tires as its a HC but not the BFG KO3 tires ( that was an option for my truck but the sales guy couldn't figure out what the tires actually were so that never got on the order until it was too late to change the truck order ). So what fuel mileage your getting actually sounds good for "town driving" and with my truck when I go to town the fuel mileage keeps increasing as I get closer to town because it takes quite a while to get the driveline oils warmed up ( and why it always shows better fuel mileage on the return trip from town because its already warmed up ) but once I am in town that fuel mileage average just keeps dropping the more I mess around town and then has to recover back to something reasonable again by the time I get home for an over all average.    I'd be curious what your sticker says for the factory weight of your truck, mine is close around that 7700 lb due to the options it has. But anyway the long and short is, vehicle weight, higher rolling resistance heavy tires and a hefty driveline and a relatively large gas engine make for crap fuel mileage in stop and go scenarios, all one can do is drive it easy off the line at each stop and as my dad had said over the years, drive like a raw egg is under your foot and that's the best one can do. Years back with a carbed engine and if the carb was getting a bit out of tune etc as would the ignition system, the fuel mileage on pickups with larger engines was just awful compared to what your getting. We pay the fuel price penalty for driving HD trucks over some little vehicle, that is the reality.
    • We had two Toyota’s with that engine in the mid 80s. We had 50 gallon fuel tanks, a toolbox full of tools, an air compressor and assorted parts for our equipment. We beat those up and down pipeline ROWs until we started buying diesel trucks. Then they became parts runners and first vehicles for our teenagers first cars. Our shop Forman wrecked them both two years apart when we hired him out of high school as an apprentice. Good thing he’s an excellent mechanic. It took awhile before he could be called a good driver.
    • I have a 2025 GMC Canyon Denali.   On a trip recently the engine failed.  The dealership diagnosed a bent valve and says there is a service bulletin that indicates to 'relace the engine'.  The truck only has about 14K miles and is under warranty.   The failure occurred 5/11/2026.   So far I have worked with GM Customer Assistance and Roadside Assistance.  Evidently no engines are available and nobody will offer a date when a new one will be.   Coming up on two months with no repair or timeline and no loaner from the dealership.   GMC Customer Assistance is 'ghosting' me and keeps closing the cases I've opened with no resolution.   Hoping someone can help me on how to escalate this issue.
