After market audio system help
Alright guys, I can't find any information on installing an after market audio system in my new truck. I've got a 2015 1500 double cab. I'd like to keep the seats in and was hoping I could fit a shallow sub under one of the seats. Any idea which speaker combination will sound the best? I listen to a lot of metal, blues, and rock mostly. I dabble in dubstep and rap occasionally as well. I'm a complete newbie when it comes to trucks and audio systems so go easy on me. Lol also I'm keeping my factory head unit (8 in touch screen). Thanks in advance.
Wow....that's 10x more complicated than j was expecting lol thanks for the response. I guess I have a TON of research and planning to do. That 20k system is insane. Too bad its completely out of my budget by about 18k haha
http://www.crutchfield.com/p_500SBRS84/Alpine-SBR-S8-4.html?tp=112&awkw=75640521625&awat=pla&awnw=g&awcr=47621715145&awdv=c
that, a line out converter, amp, and amp kit and you're golden. I installed this with my Alpine V12 amp and it rocks. Stock speakers were next on my list, but they're fine with my music choices- mostly rock, classic rock, country, blues, and a little rap.
Most importantly here is that sub going to fit under the back seat and why 8 vs 10 or 12? I'm a complete noobie to this so I apologize if my questions are seemingly retarded.
Adding a sub only adds bass. Lots of other things to consider as well.
I put Earthquake Shallow mount 8's in the rear doors, ran as full range woofer drivers. Front speakers stock GM ( for now anyway). Driven by a simple Alpine 45x4 amp. Point being, it doesn't take a lot to really wake up the stock system
Is that something I can do myself or should i take it to an audio place? I prefer doing things myself as long as I have decent instructions. I hate not knowing if the job was done correctly.
Link to the install of 8's in rear doors. Wasn't that hard. First door was difficult, figuring out where to place the driver. Second door was maybe 30 minutes. You do have to sound damper the outer door skin. Two braces in the door, upper is horizontal, lower is angled. I added sound dampener between upper and lower, and below the lower brace. Peel back the factory sound dampener and use a full 12"x24" sheet to fill in as much of the inner door opening as possible (window motor will kinda be in the way). I put back the factory dampener and used ProTecto wrap to reinforce the area over the window motor and to seal the dampener around the edges. Been my experience, adhesive on Protecto Wrap holds up well.
http://www.gm-trucks.com/forums/topic/172142-15-dc-8-lcd-non-bose-stage-1-audio-upgrade/?do=findComment&comment=1615553
Other option would be to get a couple of 6.5" shallow mounts and just reuse the factory adapters. I already had the 8's, if not, I'd have given a set of 6.5" subs serious consideration. JMHO, other than needing a little boost in power, weakest links in the factory system are the dash speakers and the rear door speakers. Rear doors have too much pronounced mid-range/upper-bass when driven. Dash speakers are also favor mid range and are lacking in high frequency details. Tried running a lot of treble boost, just made things worse, so instead I cut the mids on the factory EQ. Front door speakers when crossed over at 80hz clean up a lot and play rather loud, distortion free. Other guys do it differently, I think these would be the last to swap out. My next project will be replacing the dash speakers. Gonna try to get a 3.5" coaxial in there.
Thanks for the detailed instructions GRN69CHV. That's going to help A LOT. If I end up going that route ill post pictures and stuff. I've seen the dash speakers being replaced and it looks like a nightmare. You can only fit 2.5 tweeters in there without modification. I thought about modifying the A pillar but I have a grab handle on the passenger side for my fiance so idk how well that would work out. I've also been told a JL audio 10tlw-d4 shallow sub is awesome. I'd have to mount under the seat but then I'd also have to replace the rear door speakers with something else. Decisions decisions....
I'm looking into a 3.5" swap for the dash. It's next on the list. Have already had the A-pillar covers and the front grille out and pulled a front speaker to have a look, it's a 10 minute job at best - with 5 minutes of it getting the tools out.
I guess the guy talking about it in the other forum just sucks lol he said he broke the clips holding the pillar in place too. You will have to modify the mounts in th dash to get a 3.5 in won't you?
    • I went to order some PF63 oil filters from an on line GM parts source, and the blue PF63 oil filters seem to be getting phased out. They show the new part number as 19363567, which is a black colored AC Delco Silver product apparently marked PF63A. Some sites show a part number 12693541, which is a black colored AC Delco Ultragard Gold filter marked UPF63R.    I assume the UPF63R is the better one, but I’d be happy if I could just get blue PF63 filters I’ve been using.    Can anyone explain what is going on with the filter part number changes and any actual design changes?  Any other advice on buying OEM filters right now?  Thanks
    • thanks for coming back and posting what the fix turned out to be.
    • Only TAN I have for the product was at 5K in service miles and it was 2.71
    • If anyone lands here looking for an update - the problem wasnt with the hose, the clamp, etc... I purchased a metal Thermostat housing that just must not of been made to spec. It just wouldn't plug up the hose.. Went back to a plastic cheap housing - leak fixed. Some plumbers tape carefully placed in tandem with a clamp likely would've gotten the job done.   Best,
    • For anyone following, this is what I have deduced from this forum - and my very specific niche case. Please do let me know if you see me going in the wrong direction here. For context, I have a 16 sierra 1500 w/t. Has TC and Cargo light switches. Removed the switch to find the X1 and X2 of the S48A connection populated with wires (x1 10-14, and x2 1-5).   Took photos of the X61A-X5 to find the wires from S48A-X1 land here at their respective pins (10, 11, 17, 23 on the X5). Was hopeful that this means my X51A fuse box has the appropriate pins... No cigar. So now I will be routing wires from the rear of the X61A-X1 to the engine bay and to their respective negative relay triggers. Please see to the diagram. If any has insight as to where the S48A-X2 pins 4 and 5 land that would be awesome.   Will be attempting this sometime shortly and will likely make a youtube video out of it.   Note: please disregard fuse sizes. Main fuse will likely be 25A, all mini bus fuses will likely be 10-15A.   Here is my parts list: GM 84347199 - TC, Cargo Light, Exhaust Brake (useless to me unless I find a means to reconfigure), Aux 1 - 4. 12V 6 Way Pre-Wired Fuse Relay Box Kit with 4 x 40A 4-Pin Relays (link below - some mods required to make negative trigger)            https://www.amazon.ca/dp/B0F4KCS43B?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1 Various wire sizes (12 AWG - red and black, 14 AWG, 16 AWG multi-colored bundle) Wire termination leads for X61A-X1 (unknown at this time) Crimp connectors/Soldering Gun Heat Shrink Split Wire Loom To be continued...    Cheers
