I have a 2003 Suburban and the blower motor can lose and dropped to the kick ;panel and sat there. I thought the motor was shot (started making noise) and I was taking my daughter and her friend to a banquet. They were dress up and hair done so ran the blower I figured what the heck, motor shot have to replace it any way. Bottom line the fan milled the whole mounting flange away! I need to replace the duct work. I now have half the truck tore apart down to the duct. Looks like the bottom half of the duct might separate, looks to be held together with a few screws and what looks like rivet heads make of plastic but it might be plastic weld locations. Looks like it might be attached to the fire wall. Can this be taken apart with out opening the A/C lines? No way to attach blower motor, would like to take this one back! Any one have any experience here? Any information greatly appreciated. Thanks
Have the hvac recovered ,
Remove dash braces and brackets
SO ALL THATS LEFT IS THE HVAC AIR BOX !!!
Remove it , separate the box, replace the half and reinstall,,,
It is a bitch of a job , take pics for harness routing etc etc etc , take notes
Was still able to order the lower half of the duct ($100) so that was good. Needed the VIN was more than one stile, duel climate ect. Dealer says $1150.00 in labor to do the job. I wish I new more about the A/C and a way to recover it. Tomorrow I might look at the duct work closely. Right now I can still use the truck even though I have the front of the dash off and the glove box as well as the center counsel. This alone is a garage full of parts. Truck is a Z71 lots off stuff, thanks for the info Don.
You HAVE to recover it at a shop ,
If you try and cheat your way thru this aweful job , it WILL bite you ,
IT IS A MAJOR PITA !!!! Not a job for a DYI home wrench , at least look into Alldata . Com
Still taking things apart, major job. What have I gotten myself in to? Have a lot of stuff out but still the metal structure is not lose. Steering Colum? Does it come out the top? Looks like maybe. $1150 would have been a steal.
I told you ....
Yes , steering column goes , it ALL goes !!!!!!
Get alldata
Edited by govtech4
Found some good video (Chevrolet Tahoe A/C evaporator removal) you tube. Better information using -Plenum box and evaporator. That helped make progress. Amazed at the clueless that feel a need to make a video.
I said I found some good video. Not the type where someone has you watch while he heats up a screwdriver to melt through a quick disconnect because they don't know how to take them apart.
I’m done. Helpful tips, remove console as a whole unit by removing the seats and 2 10mm bolts and 4 screws up front. Get an illustration of the duct work it will show the location of the 5 or 6 bolts through the firewall. Watch the video I mentioned in the earlier post he is the man. But they don’t show everything. Dash stays in truck pull passenger side back and upword tie for support to roof rack. Plenty of room to work. Just a few tips I wish I had known. Be patient.
Why not post a link to the video, you could be helping the next guy
Congratulations! It feels so good to get a big project out of the way. Now...post that link!
  • 5 years later...
Wish he had shared link. Im in same mess. Garage full of parts and still not necessary the duct. Something died in mine. Smells so bad cant even be near it for more then a minute. May just get rid of it pay loan off. Im so pissed that they make it rhus impossible to get a dead rodent out of air ducts.
I have to do this to my 2000 k1500. fkn pack rat made its home in the ductwork while I was waiting to replace fuel pump. removed all the crap that I could reach. can still feel a bit more up under defrost vents. gonna tackle this myself, any advice is appreciated.
    • I’m out of ideas on this truck. 2020 Silverado 1500. 5.3 135,000 miles. Has a p0308 and p050d codes. Smokes From exhaust when cold. Compression test passed. New plugs, wires and coil on cyl 8. Same issue. New coil on 8, no change. Replaced injectors, no change. Bore scope showed oil pooled on the piston after sitting overnight. Pulled head and had machine shop check it out. No cracks. Stem seals looked good, replaced anyways. He also ground valve seats. Put it all back together and still have the same issue. Bore scope shows oil on the piston again. Leaning towards maybe a cracked ring but unsure. Cylinder looked good when the head was off, no scoring or scratches. Any ideas on what else I should look for?  Appreciate the help
    • Just want to make sure it is covered by Special Coverage N232395310 Evaporative Emission Purge Pump 2021 Silverado 1500 Custom 2.7L L3B ~100k miles I'm getting DTCs P146B and P146F. VIN 3GCPWBEK2MGxxxxxx   I spoke to a person that works at GM and he said it is not covered after checking my VIN.   Is there anyone here who currently works for a GM/Chevrolet dealership and has access to GM Global Warranty Management / Investigate Vehicle History who could explain how the VIN eligibility is determined?   thank you
    • Thanks for all that information, I might purchase one and see if it will work for me, if not they may let me return it! Yes for sure the tires are definitely within limit for my truck empty, and when I do tow I'll definitely make sure to raise the rear psi for the amount of weight that's going to be on it.
    • Yes exactly, more and more these days people/companies are afraid of liability issues so its easier just to say no rather than risk putting their neck on the line.    I will say with the Autel unit or when I used it last year on my truck, it wasn't like I could choose the 2025 model year or even the 2024 model year as that option was not there to manipulate the placard pressures but had to go back to 2023 or there abouts and then it showed up as an option, odd but that was how the software was then and I can't say one way or the other now as they throw out updates every so often. I still would talk to your tire dealer though to start with and they may do it for nothing but also they may have a comment on a better unit to purchase. All I know is that one of the large tire shops in my area happens to use these Autel units for their use and set them up to use the wifi and all of that jazz for constant updating because each tire tech has one handed to them by the shop but I just plugged it into my laptop to update it and yes if one is bought it has to be registered so you can get the link to do updates and then the unit has to be updated before its even used. I am not at all techy so it took me a bit but anyway just a heads up for anything you buy, most likely it will need to be connected to a computer to access the internet to have it updated to the latest software version before you can put it to use.   If your truck is near empty, those tire pressures you listed are a very safe upper range pressures to carry the weight, both the front and rear as I know they could be run lower yet with an empty truck. And if its a trailer and not some motorcycle your going to strap onto the front of your truck on a rack, you shouldn't have a need to inflate your front tires if your at 55 front already, its the rear ones that would need more air if you have much hitch weight.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
