I have a 2003 Suburban and the blower motor can lose and dropped to the kick ;panel and sat there. I thought the motor was shot (started making noise) and I was taking my daughter and her friend to a banquet. They were dress up and hair done so ran the blower I figured what the heck, motor shot have to replace it any way. Bottom line the fan milled the whole mounting flange away! I need to replace the duct work. I now have half the truck tore apart down to the duct. Looks like the bottom half of the duct might separate, looks to be held together with a few screws and what looks like rivet heads make of plastic but it might be plastic weld locations. Looks like it might be attached to the fire wall. Can this be taken apart with out opening the A/C lines? No way to attach blower motor, would like to take this one back! Any one have any experience here? Any information greatly appreciated. Thanks
Have the hvac recovered ,
Remove dash braces and brackets
SO ALL THATS LEFT IS THE HVAC AIR BOX !!!
Remove it , separate the box, replace the half and reinstall,,,
It is a bitch of a job , take pics for harness routing etc etc etc , take notes
Was still able to order the lower half of the duct ($100) so that was good. Needed the VIN was more than one stile, duel climate ect. Dealer says $1150.00 in labor to do the job. I wish I new more about the A/C and a way to recover it. Tomorrow I might look at the duct work closely. Right now I can still use the truck even though I have the front of the dash off and the glove box as well as the center counsel. This alone is a garage full of parts. Truck is a Z71 lots off stuff, thanks for the info Don.
You HAVE to recover it at a shop ,
If you try and cheat your way thru this aweful job , it WILL bite you ,
IT IS A MAJOR PITA !!!! Not a job for a DYI home wrench , at least look into Alldata . Com
  • 3 weeks later...
Still taking things apart, major job. What have I gotten myself in to? Have a lot of stuff out but still the metal structure is not lose. Steering Colum? Does it come out the top? Looks like maybe. $1150 would have been a steal.
I told you ....
Yes , steering column goes , it ALL goes !!!!!!
Get alldata
Edited by govtech4
Found some good video (Chevrolet Tahoe A/C evaporator removal) you tube. Better information using -Plenum box and evaporator. That helped make progress. Amazed at the clueless that feel a need to make a video.
I said I found some good video. Not the type where someone has you watch while he heats up a screwdriver to melt through a quick disconnect because they don't know how to take them apart.
I’m done. Helpful tips, remove console as a whole unit by removing the seats and 2 10mm bolts and 4 screws up front. Get an illustration of the duct work it will show the location of the 5 or 6 bolts through the firewall. Watch the video I mentioned in the earlier post he is the man. But they don’t show everything. Dash stays in truck pull passenger side back and upword tie for support to roof rack. Plenty of room to work. Just a few tips I wish I had known. Be patient.
Why not post a link to the video, you could be helping the next guy
Congratulations! It feels so good to get a big project out of the way. Now...post that link!
  • 5 years later...
Wish he had shared link. Im in same mess. Garage full of parts and still not necessary the duct. Something died in mine. Smells so bad cant even be near it for more then a minute. May just get rid of it pay loan off. Im so pissed that they make it rhus impossible to get a dead rodent out of air ducts.
  • 3 weeks later...
I have to do this to my 2000 k1500. fkn pack rat made its home in the ductwork while I was waiting to replace fuel pump. removed all the crap that I could reach. can still feel a bit more up under defrost vents. gonna tackle this myself, any advice is appreciated.
    • This is just a thought as I can't claim this is the correct thing to do but will suggest it and you can decide if its something you would try. First round up some electrical contact cleaner spray as they at least claim its not supposed to damage the components ( brake cleaner depending on the type is a real destroyer of plastic etc ) and to use that to assist to clean out any grime from the pins as well as the mechanism by spraying and working the lever etc. Then my next thought is to use silicone spray lube and not on the pins but on the seal and the pivot assembly. It may not be possible to spray it on certain area's and have to use a q tip as Davestar mentioned to keep it from getting on the pins. Dielectric grease can be fine on some things but its easy to get too much on if not careful and then gunk things up and a possible risk of getting it on the pins or sockets. The silicone spray is able to get into a mechanical component to help lube and on surfaces its just a fine film to reduce friction such as that seal. Also it can be doused off with a good flush of the electrical contact cleaner the next time for a repeat of a "clean and then lightly lube" step process to wash off any dirt that had stuck to the exterior etc of the plug.   Free advice, yes. Good advice ... now there's the question mark !
    • Hey thanks yall for the info. It apparently was the key fob - the "reserve" key fob works just fine. Yall were all over it. Great input! JRD
    • I just bought one of these.   https://www.topdon.us/collections/diagnostic-tools/products/artidiag-pro   Yeah, it`s got a cable. $250/year after 2 years. Do I want more? Yep. But, I`m not working any more and can`t afford a whirlpool in my tool box.
    • Why don't I have a good scanner? I've always wanted one when I've needed one.   My latest reading says I don't need to do a relearn on the ckp sensor on a 1995 with OBD 1.5. The relearn is prescribed for the later-model 1995's which shipped with actual OBD II when GM completed the transition in prep for the 1996 MY. I need to confirm that. Did you know forums are disappearing? Knuckleheads on Facebook... it's not the same. It's just not.   So, scanners. Again, shooting myself in the foot for having eBayed my Snap On MT2500 "brick" with all the adapters. Not that I couldn't buy another but those are getting quite old, and mine wasn't new enough to work on 2000's vehicles.   Damn it (as I'm scanning my email between paragraphs here). Did you know there's a 2000 Jimmy 2-door on BaT that's ending this morning? It's local. I want it. 14k miles. Absolutely beautiful.   Back to scanners. MT2500's are old. Solus, now that could be a contender. There's a ~2008 Verus with a system error that's basically new in box for cheap. Hmm...I'm not sure about a scanner that runs an archaic version of windows (95 or CE, I can't tell).   I want the ability to reset and rotate TPMS, test individual modules, bleed ABS, electronic parking brake controls for servicing brakes, relearn procedures and other bidirectional controls.   Snap On does an MT2600. It's a new model as of last year, marketed as their "entry" scanner. Entry? Only where $1900 gets you through the doorway plus, I'm guessing, $1000/year if you wish to keep it current. So goes scan tools actually designed for production environments. Want decent products with excellent support, you pay for it.   Everyone is raving about Autels and TopDons and Foxconns and all these newer brands that are selling the $500 "prosumer" scanners for backyard hacks like me. They're tempting...honestly. Updates are cheaper, base prices are remarkably cheaper... And you get to deal with bugs and translation whoopsies and, well, just don't use it on anything expensive, OK? Having a dealer replace an ECU because it needs to be re-imaged after an adventure in scanning is no joke. But I think most people are getting by OK with these units.   eBay on a scratch-and-sniff pro-model oldie, a shiny new TopDon, or???   God dang it, I can't stop looking at this Jimmy. I'm ready! I'll Bring The TRailer! It's beautiful.
    • I removed the OE running boards.  It looked so much better.  I wish I took them off a long time ago.     I had to put something back on for my wife.  I wanted Westin Sure Grip Running Boards but they are very pricey, like $600 plus.  I was going to go with the Ionic 41's like I had on the 2019 Silverado but went with Westin Outlaw Drop Steps instead, about $200 cheaper.  They are sturdy and functional but not super crazy about the look, but it works.
