"Swoosh" sound when braking
So I recently acquired an 85 Chevy k10 short bed and have brake issues. When I brake I can hear a loud swoosh sound and if I hold my brakes long enough the pressure dissipates. I bleed all wheels and got fluid to squirt out and seems the same. Also when braking its as if only going 3/4 down it starts to brake and aqually apply pressure. What could be the problem? Thanks
Sent from my SGH-T999 using Tapatalk
No pulling when braking but can hear that swoosh and it only brakes 3/4 down and requires extensive pressure to actually slow vehicle down. Also I noticed that on both front driver/passenger that only the middle section of disc was actually being used and the outer edges of disc was being used.
Got it replaced, changed brake booster and whoa so much less f
Leg pressure is needed to brake. Now onto the master cylinder cause its weak and catches at the end
    67elco
    67elco
  • Who's Online   6 Members, 1 Anonymous, 1,408 Guests (See full list)
