Grease points
Ryan698
Okay this is the first truck iv owned and I want to know where I need to grease things like if there are any nipples to hit lightly say every oil change.. And if so if there is a thread on this please link or if your self no where they are be patient and maybe have some pictures you could show me.. And what grease I should be using
Sent from my SM-G900W8 using Tapatalk
Should mention it's 2015 all terrain with a 5.3
My lookup guide is showing that there are two fittings that need to be greased. It isn't telling me where, but my guess would be either the front and rear drive shaft or some point up on the front suspension. I'm sure someone on here will chime in soon.
Hopefully I want to do everything I can to keep this thing tip top shape!
The drive shafts are sealed units, I think the only zerk fittings are on the front end. Been awhile since I looked as the norm now is almost all spots are sealed from the factory these days.
The steering rods at the end of the electric steering rack near tire.
Thank you., you wouldn't happen to have a picture or no what grease to use
I was wondering if the two points was on the ends of the steering links at the wheels.
Here are a few recommendations. The water resistant grease would be good to use if you drive in a lot of rain and run through water gathering on the roads where it can spray up onto the suspension.
CHASSIS LUBRICATION: 2 Fittings, 0 Plugs..........LB
Synthetic Multi-Purpose Grease NLGI #2 GC/LB (GLC3P)
Synthetic Water Resistant Grease (GWR3P)
DOMINATOR Synthetic Racing Grease NLGI#2 GC/LB (GRGCR)
    liddlera
    liddlera
  • Who's Online   1 Member, 0 Anonymous, 424 Guests (See full list)
