Vipre Alarm / Onstar
Does anyone know if it's possible to make Viper's remote start work with the OnStar remote start phone app?
What advantage does it have over built in onstar? It may have faster response, but after LTE upgrade, onstar should be faster.
I want the 2 way remote that Viper has, but don't want to pay for a subscription with Smart Start being I just renewed my OnStar account.
  • 3 weeks later...
Just an update. I got the Viper 5706v installed and I can still use the full functionality of my OnStar phone app. No need to get the additional Smart Start module or the addtional subcription fee.
  • 1 month later...
Sorry for resurrecting but wondering if this alarm works with the original key fob or do you have to carry an additional remote for the viper?
    flyclt
    flyclt
  • Who's Online   5 Members, 0 Anonymous, 636 Guests (See full list)
