2014 rear differential
ocracokenc
Does the 2014 Silverado with the 4.3 and 5.3 have the same rear end. I have the 4.3 EcoTec WT2 trim with a G80 and 3.23 ratio. I am thinking about a re-gear but in my search it seems the 5.3 may be different. What technically is my diff called? Like say a GM 8.75" or such. Thanks and sorry if this has been discussed but I could not find it.
On a side note it is funny my truck is a EcoTec, My boat motor is a E-Tec and my wife drives a EcoBoost car. ECO must be in style LOL
No. 4.3 uses the 8.625" rear axle. 5.3 without max trailer package use a 9.5" axle. Max trailer 5.3 and all 6.2 use a 9.75" axle.
Thank you, So my 2008 Crew Cab with the 5.3 has the same rear diff as my 2014 double cab 4.3?
Yeah basically haha
No. 4.3 uses the 8.625" rear axle. 5.3 and 6.2 without max trailer package use a 9.5" axle. Max trailer uses a 9.75" axle.
For some reason I was thinking the 6.2 trucks with the 3.42 gearing got the larger diff as well.
The 6.2 in general comes with the 9.75" axle
+1
All 6.2's have the 9.76"
    Fishboat
    Fishboat
  • Who's Online   1 Member, 0 Anonymous, 525 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
