Free Horsepower
Black02Silverado
Found this and thought it was a trip. It is one way of getting your ride to go faster in the 1/4 mile. To get the full effect you have to read it as you go.
Free horsepower
One slick Sentra.  :cheers:
I think the funniest thing about these pictures is that during the 'tire spinning and smoking" shots, the car is being held in place by a couple of people in the back!
 :cheers:  :chevy:  :D
 :cheers:  :chevy:  :D
Can't you just picture the guy who asked the questions reaction to all of this "free" horsepower? :D
I think I really did pee my pants, that was to hilarious...
:lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :lol::lol:  :cheers:  :chevy:  :D  :D  :crackup:  :crackup:  :crackup:  :crackup:  :crackup:  :crackup:  :crackup:  :crackup:  :crackup:  :crackup:  :jester:  :fume:  :crackup:  :crackup:  :crackup:  :crackup:  :crackup:  :crackup:  :crackup:  :crackup:  :crackup:  :crackup:  :crackup:  :crackup:  :crackup:  :crackup:  :crackup:  :crackup:  :crackup:  :crackup:  :crackup:  :crackup:
