921 Led Issues
Has anyone else found that the 921 LED is too long to replace the license plate light stock bulbs? The ones that I got hit the reflector so that you can't get the connector to go all the way in and turn.
Sent from my SM-G920V using Tapatalk
If anyone is curious about ebay led's I have been a bit of a guinea pig for them. I've tried all of these:
t10 License plate bulbs
5W Cree - These have been the best colour and output in my opinion and they have lasted the longest. They have a very good resistor built into them, unlike the cheaper ones. 5000k-6000k
Fake Cree - Very blue, didn't like the colour or the ouput 6000k-8000k
These and These are very similar, and you will need to make sure you order lots of them as they start to flicker in a very short amount of time due to cheap resistors, they are also fairly blue, 6000k-8000k
I really liked the output of these ones, but they were too long for the license plate bulb housing 5000k-6000k
These were also a nice colour, but not as bright of an output as the 5w cree's (I'm keeping these as backups for when my cree's die) 5000k - 6000k
Again these had a nice colour, but ended up flickers very soon 5000k-6000k
For reverse lights, I've tried
Cree 30w - these have been the best, very bright, very nice white 5000k-6000k colour and the design creates the best light projection
Cree 25w - These are second best, but the output isn't as good as the ones above.
Cree 7w - Not bright enough, only projects straight back and doesnt light up the road.
With the cree 30w reverse lights and 5w license plate lights I have a very nice colour matched setup on the rear. On the front I have 5000k HID's and These 80W Cree H16 Fog's and they're pretty close to matching. I need to take some pictures at night to show how good they really look.
http://www.gm-trucks.com/forums/topic/170746-project-summit-build/page-6?do=findComment&comment=1653368
Arent 921 cargo and reverse bulbs? 194 is what you need for license plates
These are what i bought and they fit perfect and look great
http://m.ebay.com/itm/PHILIPS-LED-VISION-6000K-194-12256-TWO-BULB-PARKING-SIDE-MARKER-LICENSE-PLATE-/131520989437?txnId=1114476023003
