Anyone have pics after removing the front license plate bracket? If I remove them how big of a hole will it leave in my bumper?
Not sure of the hole size since I live in a no front tag state but if it is pretty bad then you can order a replacement center section of the bumper. GM calls is a "skid plate" for some wierd reason.
Ya I'm gonna take it off next week when I go home. Hopefully it isn't too much of an eye sore.
There is some sticky tape holding the top and two rivets you'll need to drill out at the bottom. The remaining holes are just under 1/4 in.
Edited by loadies
Loadies, did you remove your front plate or did your truck come like that? If so, did it leave any scratches or scuffs?
Edited by GarciaLTZ
Not a close pic, but if you zoom in you can see the two holes. I removed mine a little over a month after getting the truck. Your left behind with some lines of dirt that just wipe away. Looks like it was never there.
Edited by jroyston13
I did it. No marks at all short of the two small holes. Did it as soon as I got the truck home.
so i just attempted to take off the bracket...and wasnt really sure how...which i admit with some embarrassment and laughter considering i leveled the truck and installed the exhaust myself. it seems this pins or whatever the hell they used does not unscrew ?
They are rivets and have to be drilled out. I did it to my friends truck took a whole 10 min, 5 of which was getting the drill haha.
Just removed the front license plate bracket from my new 2016 1500 LS. Three small, barely noticeable holes remain, two on top and one on the bottom. Much better.
Edited by Muley
  • 2 years later...
Sorry to revive this but does anyone know the bit size to drill these rivets out? And do I just drill straight into the center of the rivet? Thanks
    rayredbone
    rayredbone
  • Who's Online   2 Members, 0 Anonymous, 529 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
