Chipped keys
Hey all,
I bought a 2012 GMC Sierra. The dealership gave us 1 factory key w/ fob. Do I have to go to the GMC dealer to get chipped keys?
Dont have to go there. Other places will make the chipped keys. The keys from other places will be cheaper but not say GMC on them
Not necessarily...I would though. We've had customers come in with aftermarket keys they had cut and either wouldn't program or lost program.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
