HD Conversion
Has anyone converted their front end to HD just curious I know the 05 and 08 models most achieved them by simply swap and swap just curious if it was possibly with our 1500 questions like would be a plug and play situation bumpers,grill,and etc. my concern is the bumper I'm afraid the frames are different thus making harder to complete a project like this. Anyone can chime in on this would be greatly appreciate it $$ wise yes would be expensive but just wanted to see if possible.
It can be done much like the 2013 and older trucks, which I've personally done myself. In my personal opinion, whatever that's worth, the PROPER way to do it, is to cut the front frame horns that support the main bumper bar and scoot them down to compensate for the "taller" front end, plate over the open end of the frame that you've cut, with enough excess below to reattach the frame horn and gusset behind them and under the frame rail with heavy square tubing. Other than that, all you have to do is buy the parts.
Thanks for the info good to know it's possible now the hunt begins for some pics ...
Btw those with front sensors and front collision alert would I run into issues or would the front sensors go out of whack.trying to cover as much ground before anything is considered
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
