Chrome or Black
I am having a 2.5 leveling kit installed next week and I thought I knew what I wanted as far as wheels went - Chrome...however, the guy doing the install was going on and on about how good polished black wheels would look...now I am back at square one.
thoughts on Black vs. Chrome? My truck is a 2015 Ocean Blue Metallic and it has the Chrome honeycomb grill and bumper
If it matters, I am going to put some 285/70/17 or 295/70/17 on so there's going to be a lot of black rubber showing...that's why I'm leaning chrome.
  • Replies 33
Depends on what other accents you plan to keep or go with, but with a 17" I'd lean towards something shiney. LOL, so Chrome or Gloss Black, no flat black.
Hope that helps! HAHA
I'd vote black. I have a 2015 Sierra Stone Blue and I've put a lot of work into removing all of the chrome from the truck. Door handles, mirror caps, emblems/badges etc. The only pieces I have left are the rocker panel molding, and the window trim, and they'll be done very soon. I just feel that blue w/black accents goes together so much better than blue w/chrome and black accents.
Josh
Josh
I posted this in a thread similar to this one. Black Chrome, win/win.
looks good! what size are you running for tires/wheels...do you have a leveling kit?
Thanks.
Its the RC 2" level and then OEM Sierra 20x9 wheels with Cooper ATP 275/60/20 (33") tires. I also have 1.5" spacers on to push the wheels out.
:chevrolet: I'm old school too! Chrome or Black chrome.
Going through second childhood, Chrome!! Chrome always has been classy and with continue to remain so through this fad
I have the shiny black 18's of a midnight silverado on my Sierra. Wasn't sure I'd like them, but once I saw them mounted, loved them. Go gloss black, or black Chrome like rawyzf
Did you post pics somewhere?
Sent from Tapatalk App - Samsung S6
Haven't taken any good pics that you can actually see the wheels in, dark truck, dark wheels, don't photograph well with an iPhone.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
