Level lift vs Suspension
If you decide to go with the ProComp lift, note that it will push the front track width out +/-4". I added 1.75" Bora spacers to the rear.
I'm getting the lift put on today. They said we can evaluate the spacer and tire space difference issue after they are done. I showed them your post and they said they recommend adapters instead of spacers? Not sure the difference but would you know?
Awesome. So after reading that thread, from your experience if you go less than the 1.75 will you have to trim the factory studs
Actually, It is going to be dependent on what wheels you are running. Some wheels have pockets in the back of them to allow for the factory studs. If your wheels do not have pockets you will need to trim if using 1.5" or less. There is a photo within that "spacer" thread that shows the differences.
Did they finish the lift? What kit # did you go with?
Same as you! 4 inch pro comp with steel. The level kit is coming off as we speak. I spoke to them about the spacers and that's when they mentioned "adapters" would be better. I'm just gonna look at it when they are done and probably just order adapters myself and put them on. I'm running I think the same wheels as you, Fuel Mavericks with +1 offset. So not sure how it's gonna look on mine but if 1.5 was number I thought I might need then didn't know of hat would work without trimming studs?
  • 1 year later...
i just got a 4inch pro comp lift out on my truck and I have a whole lot more fender/tire gap! I'm running 33/12.50 gap you would see more with a 6! Kinda upsetting!
Not sure I understand your post. What is upsetting?
lost me too lol
    needafix
    needafix
  • Who's Online   3 Members, 1 Anonymous, 616 Guests (See full list)
