Brakes leaking?
So I got a question in regards to my breaks. My brother seems to think they are leaking but I just figured it was some road grime but let me know what y'all think. Also if it is a leaking issue will the dealer cover to fix it? My truck currently has 42K on it so would it be covered under the powertrain warranty?
763E7B01-191D-4775-9D28-59A4CCD922CF_zps
F02F6342-31A0-4A81-8D30-EF92002EB254_zps
Needs an axle seal. Should be powertrain warranty. May end up needing parking brake shoes if they are soaked as well.
Has this been a common problem on this year?
It's not year specific really. It is somewhat common. There is a possibility that the vent tube may be plugged, and then the pressure needs some sort of escape, so it leaks out the seal.
I agree that you have an axle seal starting to seep a bit. Nothing on your wheel or tire, so I wouldn't be too worried about it. You should check your axle vent and make sure it is OK, which it probably is. Fairly simple fix that I believe should be covered. Did you check the level of your brake fluid?
