Hey Cops Trade in those Vic's
JonesNTN
Haha...their going to gas saving cars, and out here the Henderson PD is going to an almost exclusive SUV force (mainly Tahoes, with some Expeditions), and a couple of Crown Vics for chases, though they have some of the pursuit-rated old-body style '99 Hoe's too. :thumb:
A Saturn for a police vehicle is one of the dumbest things I have ever heard... :eek:
They have a few of them here in Maryland that the police use as 'stealth vehicles' mostly out on the interstate.  On really busy travel weekends, everyonce in a while, I will someone pulled over by an 'unmarked' staturn with all kinds of concealed lights flashing
bummed.
pretty tough to outrace those.   :eek:  A vette running 95 and a saturn running what 45-50???   :cool:  Badguys are 1 up on the cops there
Also around here the big new thing is dodge intrepeds (UGLY).  One dept is dumping the 5 new ones it bought cause they are so unreliable plus they had a big wreck which 4 were totalled (haha).  It was like a blues brothers scene I guess
I see some cities are going to Impalas here!
Houston has.  I cinda like those though.  But I liked the mid 90's SS the most.
They just got a few Impalas to replace the Crown Vics here.
Strongsville, a fairly good-sized suburb South of Cleveland has a good number of Impalas.  Thankfully our place hasn't jumped on that wagon(too small) despite having a chevy dealer within a 2 block walk down the street.
Euclid, an eastern burb of Cleveland ran an Intrepid when they were new.  Now I don't see them anywhere.
Henderson PD is going to an almost exclusive SUV force (mainly Tahoes, with some Expeditions), though they have some of the pursuit-rated old-body style '99 Hoe's too. :thumb:
Sure, rub it in after I saw a female officer driving a Hoe last year when I was out.  Oh well, we've got a OBS GMC Yukon XL or Burb that will be a supervisor vehicle someday(they take forever to change cars over)...now if I could only work the charm to get to drive that beast.
I think we might need some of those saturns here .
People are getting used to the avalanches that the state patrol uses as unmarked vehicles
The cops here are dumb, they try to use Crown Vics with 5 foot whips on the trunk as unmarked cars...you would have to be blind and stupid to not know that those are cop cars.
