Hey guys I have a question for all of you. I have a 2003 Silverado 1500 that ORIGINALLY had a 4.8l in it. As some of you know, I had a 6.0 swap done on it 2 or so years ago.
Recently, I got the dreaded P0300 code. After all of my testing, I have come to the conclusion I have a bad fuel injector. So here's my question.
I removed one of the fuel injectors, which is a Delphi #25317628. After shopping for a new one, I have been given three part numbers and can't make sense of them. I am told a AC Delco OEM injector is #17113698. I have also been told that this is the SAME injector as a #25317628. So I am leaning towards this purchase.
However, can anybody tell me what a #FJ10062 is?!
Given that my injectors are more then likely from my 4.8l, I was considering swapping them all to injectors for a 6.0l. But from my research, the 4.8/5.3/6.0 all use the same injectors?
Thanks in advance!
They do all use the same injectors. Bugger doesnt happen til 8.1
Pull one of yours and see how many holes, then order the same ones if you have determined it as the cause. Did you check fuel pressure and the condition of your O2 sensors? These engines do not have common fuel injector issues, in my experience the p0300 code is often misdiagnosed, and the true cause is leaking intake manifold gaskets as the GM ones from 99-07 shrink over time and allow leaks causing mixture issues. As old school as this sounds, you can still pull the plugs after a hard bit of driving and see if one cylinder is grossly lean, tiny variances are not noticeable.
  • 6 years later...
As a fellow 4.8l 1500 silverado er, I used rockauto to reference the injectors. The ones in my fuel rail are the 2 hole ac delco oem injectors. I swapped them out for the 4 hole version. Make sure to check the injector o-rings for size and condition. This may help alleviate any possible air leak behind the injectors "P-0300".
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
