Bilstein
timstruck
hey all
where is the best place to get a set of these 5100's? spent enough time reading through the millions of posts on leveling and think i want to go with the bilstein set up. i know its not the cheapest, but sounds like a great value in the long run. plus, im crossing 30K in mileage, so shocks will need to be replaced soon anyway
thanks!!
I got mine at 4 wheel parts. If close to a store, have them shipped there. They have a sale from time to time.
Did they install them too?
They will. Not sure the cost. I had a local independent shop install them. They need a spring compressor for the fronts. The rear shocks are fairly easy and I could have done those. But a good shop with a lift makes short work of the rears. The fronts a little longer. One or two levels up from no lift (stock) on the front 5100s leveled my truck.
Got mine at Allshocks.com. I installed the back; dealer did the front and checked alignment.
