Boat Motor Recommendation
RyanbabZ71
Ok for a Bass boat what do you all recommend for a boat motor
Heres the options
MOTOR UPGRADES
Motor Estimated Speed** Price Difference
Mercury 9.9 EL  -  $-370*
Mercury 9.9 EL 4-STR   -  $-210*
Mercury 25 EL 26 - 28 Standard
Mercury 25 EL 4-STR BF 25 - 27 $ 1,040*
Mercury 25 ELPT 4-STR BF 25 - 27 $ 1,390*
Mercury 40 ELPT 4-STR 30 - 32 $ 3,055*
Mercury 40 ELPTO 31 - 33 $ 1,400*
Mercury 50 ELPT 4-STR 32 - 34 $ 3,945*
Mercury 50 ELPTO 33 - 35 $ 2,045*
In my opinion and many other's, you should always max the motor to the boat's rating.  If it says rated to 60HP, get a 60.  I'm not sure the type of conditions you will fish, but too small of a motor on a larger boat can get you in more trouble than you think.  The motor can't handle the boat's size and you cannot safely control the boat in harsh conditions.
Plus, more HP means more speed.   :crazy:
I am not familiar with boat motors, especially the ones listed above. But we used to have a boat with a Mercury motor and it was pretty awesome and reliable, but really sucked the gas!
I have a 16' aluminum dual console fishing boat (not a bass boat but a fish and ski type) I have a 50 hp Merc on that since it was new and it does ok. I agree to put as much motor as you can afford on the boat. I know my boat iss rated to 125 hp. I just cant afford 125hp. :crazy:  Mine is a 2 stroke and will push the 700 lb combo to about 35 mph. Doesn't matter if is 1 person or 4 it will still go 32 to 35.  Good Luck. Hope this helps
Go with a 4 stroke no matter what HP you get. It is more money but the noise level and economy makes it very worth while. I was at the Baltimore boat show last weekend and I test drove a 24' Scout walkaround with a 225 Yamaha. You couldn't hear the engine idle and it was very quiet running.
we have a summer cottage and are on a chain of 3 lakes.  Not harsh conditions at all.  We have a 5 or 10 mercury HP motor now and it flys.  One boat is rated fro 50Hp and the other is rated at 75.  Id like the largest motor but dont think i will ever need it.
I am thinking the 40HP will work out fine.
I'm no boat expert. But I say go for the max! :crazy:
I'm not trying to influence you into a bad decision, but I say if it's rated at (for Example) 50HP, then put the 50HP in it. :seeya:
Kinda like putting an a 350 V8 in an S-10.You may never need it, but you'll always use it.  :lol:
Ryan
From past experience with 2 new boats, get the biggest motor the bold will hold.  :crazy:
On both boats I could not afford to go with the most motor and a year or two down the line I wished I did. I was in the process of trading up my 90 hp to a 150 until I found out the price. My dealer wants my 90 plus $5900 for a new 150 installed. For that money I can trade in my boat, get a new one with a 150 and come in a couple thousand cheaper....
If you are just going to use the boat at the camp and nowhere else, a cheaper alternative would work out good for you. If there is a slim posibilty of taking the boat elsewhere....get the bigger motor
Good luck  :thumb:
    DaleB
    DaleB
  • Who's Online   5 Members, 1 Anonymous, 1,522 Guests (See full list)
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
    • Yes. You need to check out that thing, and the hub further.
