Hi, I have a 2008 Silverado RWD, it does not have a traction control enable/disable button next to the power outlets under the heater/ac controls. Can I buy that Module and install it? is the switch plug and play into the harness?
Module: http://www.ebay.com/itm/OEM-Traction-Control-Panel-Button-Switch-2007-2013-Tahoe-Sierra-Silverado-NTO/181628325200?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D33205%26meid%3Db672ee448aea427c935c7319dad7a3ce%26pid%3D100005%26rk%3D1%26rkt%3D6%26sd%3D361169028714
Edited by Jack1121
Don't waste your time, lot more to the system other than the switch (that is not the module, just the switch btw). Master cylinder is different, ABS module and pump/valve are different, ECM is calibrated different, chassis wiring harness, etc. are different.
  • 7 years later...
Yes, you can.  Behind where the button would go is a wiring harness connector that will plug into the button (module can be purchased online, around $35, has a little cubby to the right of the button).
Its wired up, sure, and connected to the fuse box (#8) but you can only use it for an accessory.  I use it for my KC cab lights.  Works great.
Your computer is not programmed for TC, but you CAN get it updated.  Youd have to also run sensors for motion control to each wheel.  Too much work.  Just use the button for an accessory, and like me, quit buying cheap trucks 😉
Looked behind the cubby in my 2008 chevy silverado 2500hd duramax with the heated washer fluid button, I did not see another plug to add TC control button, is it taped up in dash? Or should I wire a switch to the fuse like said above? Sick of the defueling when tires spin
