Air Bag Suspension
Rock1500
So I am looking to finally get my 2014 truck leveled. So while I was thinking of doing that, I was thinking of why not also having an air bag suspension installed. Can anyone tell me the pro and cons of having one? You need to put a compressor unit somewhere correct? Where do people normally put them?
Thanks
You don't need to put an air compressor in, is just ideal if you plan on changing the pressures quite regularly, you can run 2 air lines out the back or somewhere and air up or down with a standard air compressor.
Sent from my SM-G920W8 using Tapatalk
Pros, prevents a lot of sway towing, keeps the back end from squatting. Cons- ride is a lot more rough.
Sent from my SM-G920W8 using TapatalkPros, prevents a lot of sway towing, keeps the back end from squatting. Cons- ride is a lot more rough.
Yep, as much as i like the ability to raise and lower, bags are WAY more rough riding. Too much for me if its my daily driver.
They are only rough though when inflated correct? Which is really only when towing.
I know add a leaf systems are an alternative but they are stiffer always where as bags can be inflated or deflated
This is somewhat true. It was Definitely stiffer when inflated, but seemed stiff when deflated as well (just not as bad). Regardless of inflated or deflated, it still seemed stuffer than stock. This was on a 2004 dodge dually tho. The only time it was semi-comfortable was when i was running a load
Bag manufacturers require a minimum psi, the ones I had on the 2k14 were 10psi, which even with that changed the ride quality
This is somewhat true. It was Definitely atiffer when inflated, but seemed stiff when deflated as well (just not as bad). This was on a 2004 dodge dually tho. The only time it was semi-comfortable was when i was running a load
That's cause you were riding a dually I think. Duallys are stiff in general. Did you have the truck before adding bags so you could compare before and after?
Yea i installed them after so i was used to the stock ride before. And as JcMont just said, they are never truley deflated. They hold a minimum psi that affects the ride
I have the Ride-Rite system on my '15 Sierra and have noticed no discernible difference in handling. I keep about 7psi in the bags which is practically deflated, barely raises the back end. I don't see how they could possibly have a significant impact on ride or handling. Of course, if you inflate beyond that, I can see how the ride would be more rigid. But that's what they are supposed to do.
I"m in the same boat. I want to do a level but don't want the squat when pulling the boat or anything else. I've been looking at the Loadlifter 5000 and if I'm not mistaken you can deflate them all the way. The 2000 series require a little air left in them.
My buddy has a 1 ton Dodge and you can jump on the bumper and it won't move so there is no way it will ride good unless there is enough weight to compress the springs some.
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 418 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
