2in level vs 2.5in
I know you can fit 275/65/20 on a 2.5 level. Is there that much of a clearance deifferece between the 2 and 2.5 level. I am just saying because I'm not going to change the rear blocks so why buy the RC 2.5 if im not going to use all the parts. The 2 in keys are a lot cheaper.
Here's my truck with 275/65/20 and 2 inch rc level..only rubs the carpet liner on a full lock turn on occasion
I like no tube steps, but my short gf wouldn't be able to get in my truck. Amp research steps are on my list
I'm not a fan of running boards, but I've got to be honest, they don't look bad on your truck. Your truck was my inspiration for going with 275/65's !
You know you could just call Rough Country and just order the specific parts you want. For example I called and ordered just the front 2.5 inch pieces. and DONE
I like my truck sitting perfectly level, so I went with the 2.5" front-only level from CCM offroad.
    zibzer2
    zibzer2
  • Who's Online   4 Members, 0 Anonymous, 739 Guests (See full list)
