Denali Grill on 03 Tahoe?
Has anyone attempted to put the Denali style grill(the chrome one with the round holes in it) on a Tahoe?  If so how hard was it? And where did you get the parts?
thanks
Not a Denali grill but for X-mas this past year I got a Putco Punch grille for my Sierra.  Seeing them side by side the difference is obvious but I think, for what it's worth, it looks pretty good.  Had a few misgivings to start but it's really grown on me.  Installation is easy 4 or 6 screws and clamps that hold it onto the factory grille.  Cost... as memory serves something like $150.
Hope it helps.  Probably can get a newer clearer picture if you're interested.
Thanks JAFO.  You truck looks alot better IMO.  The problem I have is the the Yukon and the Tahoe grill is different.  I went and talked with the local Chevy and GMC parts departments and basically what I found out was that I could replace my grill with one made for the Yukon, because all the bolts are in the same spot, problem is that it would have the GMC letters on the front.  Looked at the GMC logo and its part of the plastic so there isnt any way to get around it unless I cut it out.  Probably what I am going to do is just keep my grill and get one that has a similar pattern.  I saw some made by DJ Motorsports and Trenz that I like.
Apex, sorry!  Guess I sort of vegged out and didn't notice you had a Tahoe... :crackup: Check out Putco's website.  They have Punch grilles for the Tahoe as well as grilles without the GMC cut outs (part # 84115).  Perhaps you could do a little surgery to the Yukon grille to remove the letters and add a bowtie... say like the ones from the front of LT-1 Camaros or those offered here to the front.
Hope this sort of makes up for my "blonde" moment, as I've been told they're called.  Once again sorry.
Good luck with whatever you decide!
Apex, you would NOT be able to bolt a Denali grille onto your tahoe with out extensive modification to your tahoe's front end. Its important to notice that the Denali grille and a regular Yukon grille are more different than just the holed insert, check the pic and you'll notice what I'm talking about. Not only would you need the new grille, you would need Denali Turn/DRL lamps, Denali or Yukon headlights, and if order to fit the two new pairs of lamps, your would need yukon or denali (either would do) side fenders (yes the entire front side panel), and a GMC hood. Also take a look at the bottom of your Tahoe grille and you'll notice it is straight. Now look at JAFO's grille, then notice the how the bottom of his grille is lower and the bumper is different to accomadate it. And if you were to bolt on a denali grille you would need the denali bumper cover for accomadate that grille.
To see exactly why you would need the new fenders and the new headlights, click on the World icon below this post, and look at the differences between the front of my Silverado with a Tahoe grille, and my Denali. You'll see that the headlight is the main problem as GMC versions have different fenders and hoods to accomadate the GMC headlamps.
Dont worry about the "blonde moment" JAFO, I have had many of them.
Thanks for pointing out those differences Silverado3500.  I didnt notice the bumper difference on the Yukon's.  Basically what I wanted to do was have the punch style grill that the Denali has(the one with the round circles).  I like the way the Yukons/Denali's have that large area for the grill, but this is just getting too costly.  I think I am going to just put a punch style grill on my Tahoe and not remove the entire grill.  I saw one that looked good on stylinconcepts that I may buy.  Either that or I will go with a billet grill.
Thanks for all the help guys!
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • I agree, there is no one answer fits all as every rig is different, one may be pulling some little aluminum fishing boat while another is towing a monstrosity that weighs a lot and hopefully the owner if the rig has some prior experience to know what drive mode they should choose.    It also struck me and this is from watching a few of those boat ramp escapades videos in the past, Ford being one of the vehicles that has the auto front axle hubs and sure enough its found out that one hub has crapped out and won't engage and may not have manual hubs to even select on both sides so they are on the boat ramp stuck with no four wheel drive and spinning .... they flat out need a tow to get up the ramp and deal with the vehicles new found issues. That can happen to all brands of pickup, finding out either four wheel drive or 4 low isn't working right at the time its needed it to work as some electronic crap has failed.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
    • The use of absolutes like "always" to describe gear selection, and giving free advice at a boat ramp sounds like a recipe for disaster. It's a boat ramp, not a farm, for starters.   IMO gear selection should depend on the obstacle. If low range is working and this is a slower speed, controlled ordeal, I'd keep using that.
