Questions about gears
Ok so I just added 33" tires to my '15 Silverado 5.3L 4x4 CC. I have 3.42 gears, do you guys think that is acceptable to run or should I be looking into re-gearing. I have the 6speed transmission.
33's and 3.42 gears work just fine, speedometer will be out a bit from the larger diameter tires though.
Sent from my SM-G920W8 using Tapatalk
Should be fine. If you had 3.08 and 33"s you would defintately notice and want a gear change.
you sure? i heard people saying v6 with 33s should be fine
Only a 56rpm difference between 32" and 33" tires @ 70mph with 3.42's
Speedometer is only off by 2.5mpg @ 70mph as well
33" essentially turn your 3.42's into 3.32's
You'd want to add 3.53's if you wanted it to feel the same as before
I guess I jumped on the bash 3.08 bandwagon there. No offense. Prob not a problem with 3.08 with the hp / tq these engines are putting out today. :cheers:
My stock tires were 255/70/17. The tire calculator says thats basically a 31" tire. So with it being a 2" difference does that take my gearing more down to 3.22?
It's not bad but anyone with a 3.08/33 combo will need a tune to change shift points. With a BB tune my truck pulls harder than it did from the factory.
you'll be fine, I've got a 6.5" lift and I'm running 35's with 3.42's. I've lost some power but the supercharger and headers will help out with that little issue.
    appletrav
    appletrav
  • Who's Online   1 Member, 0 Anonymous, 316 Guests (See full list)
