37" tires too big for 1500?
I want to do a 9" McGaughys lift with 37" tires, I've heard that might be too much strain on a 2wd 1500, is that true? I planned on doing 24x12 with 37" tires with the 7-9" Mcgaughy lift set at 9"...anyone know if this will screw up my truck in the long run? I would go with 22x12 on 35's but the Mavericks are on back order till next year and I dont want to wait. Will the 37" work with a 9" lift on the 1500 2wd?
What is your gear ratio in the rear diff? That is where the problems come from. Bigger tires make for a higher gear ratio and robs a lot of low end torque to move the truck. If you're going to put on 37s you may want to look at regearing the rear end.
I am not sure the gear ratio, but I do plan on regearing once I put the tires on. My truck is a 2010 which has smaller wheel wells than the 2014+ body styles, Im just worried about having to cut the fenders to make them fit without rubbing.
