3.08 to 4.56 Gear swap?
Neutril
Hmm. Well, I'll stick with the 4.10s for now. I have my eyes on 2012 cummins I may trade for. If not then I'll go up to 37s and 4.10s shouldn't struggle too much with that.. I hope.
yeah i thought about trading mine for a diesel but i have too much money in this truck and dont want to start all over,
  • Replies 84
i know what you mean, i ordered every thing for the front and rear and itll be dropped off on the 18th for install, cant wait, i went with the 4.56
Did you get it put in the shop today?
I just now literally just dropped it off, I'll get it back on Wednesday
4.56 gears getting installed 4e5de3b04403c8491000f25d98194206.jpg00f6ad025196c33d9cdeaddb870e2d3f.jpg676200d4d695decd02949a924c234fe9.jpg
I think you made a good decision with the 4.56. The difference is going to be amazing coming from the 3.08 with those 37's.
yeah, that's what I keep hearing, I can't wait to get it back and feel the difference
I need some help. I have a 14 Silverado v6 2wd with the 3.23 on 33s. I want to upgrade the gears to the stock 3.72 plus add a locker since I don't have one. I'm not familiar with any of this stuff. What would I need?
2014 Silverado 2WT CC Summit White 4.3L V6
DROPKICK Edition
IG: jorge_dropkick_rangel
Just need the locker and gearset as long as the axle splines are the same. Which they should be
DROPKICK Edition
The V-6 trucks have the 8.6 Rear Axles. gear sets and lockers are readily available.
RT
RT
So would my best bet be to switch to the stock v6 4x4 assembly, gears, differential? I think those come with the 3.42 and the g80. I mean something that comes from a stock one should fit no?
DROPKICK Edition
So by my calendar today should be the day, everything still on track to get it back today? I'm about to start looking at the shop you ordered from. I'm changing my front bumper and then getting gears. I'm getting tired of doing appearance mods, need some performance mods in my life!!
i have only about 20 miles on it so far, it shifts Faster then it did before, I now have 6th gear, and going over highway overpass and hills it stays in 6th gear, it does not down shift like it did before, I love it
Awesome! Better get up and go? Sounds like initial review shows as all good and well worth it? I'll keep my eye open for any future updates on the gears as I still have a few months at the least before I get to do them
Yeah a lot of get up and go, well worth it
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 545 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
