ANZO headlights, CONDENSATION. 700$ HEADLIGHTS! CA
Chevysousa
So i already contacted the company about my first set, it had an extreme amount of condensation on the right side headlight, the left was ok nothing on it. Now i got my replacements and both are having condensation issues. Has anyone herd anything about this? or a fix? this is quite bullshit on the quality these guys say they have with these headlights.
they are purchased off amazon and when i first made my complain they contacted anzo and they sent me another pair. so i have 2 sets of anzo headlights... 1 with no condensation the other 3 with condensation..like what the F. im currently waiting on a reply from them for there next step... any information on a potential way i can fix this.
This is why I like OEM lights. You can either identify the cause of the leak and seal with silicone on the outside and/or add breathable membrane to them to allow condensation to get out.
I have a set of spyders and I get condensation when it rains on my left headlight. I just popped the cap off the back a little and it doesn't get any more condensation. They said it could happen and to not worry about it too much. You could always try to open them up and reseal them or silicone the edges to see if that fixes it.
friend of mine put anzo headlight in his 2013 2500 had the same problem, they sent him another set , still condensation problem. he sent the first set back got his money back and still has the second set they sent him lol. he has them for sale and put his factory headlights in for now
Never had any issues with mine and I've had them for a long as time.
2014 Silverado 2WT CC Summit White 4.3L V6
DROPKICK Edition
IG: jorge_dropkick_rangel
