OnStar remote link coverage
infamous9
Is it possible to remote start my 2015 Silverado from the onstar app if I do not renew my onstar sub? I've read somewhere that you can use it for 5 years, but haven't seen any confirmation on that.
As long as you use it once during the initial trial period it is good for 5 years free. At least that is what Onstar told me last year, may have changed by now.
That will be great! Extremely nice when not within range with fob
In the Winter I start the truck when I'm at my desk. It takes me almost the whole 10 minutes to get to the truck from my desk.
It's not bad to have..... I wish it had at least a run timer in the app like the Remote Access my Fords have to show how long the truck has left before it shuts off.... or tells you somehow. I would be willing to give up the tire pressure and fuel thing which I find utterly useless for a simple timer in the app lol. Oh.... and let you know the truck started.... like vibrate the phone or something.
If you have the app open in front of you. If the phones screen times out because it takes it a while it doesn't say anything to you..... or vibrate or otherwise. That's all.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 970 Guests (See full list)
