2015 Accessories For 2016s
savaytse66
The Z71's floor mat retention tabs are in different locations than the tabs on the other trim levels? I took the Husky Floor Liners right from my '14 to my '16.
Thanks a lot,
That means I was conned on EBay........the box was all messed up and the number tag taped on.......must be for a pre '14....back it goes!!!!
Glad I could help!
Thanks a lot,
Glad I could help!
Thanks, again Saved me $84.....wouldn't have pursued it figuring it was my fault for ordering a '15 and they were different.
Wow that's great, almost as good as the time I found a $50 bill on the ground!
Hello,
We will be glad to help with any needs once you are all set with the selection. With 100 % positive feedback on Amazon, you sure will get a quality service. Hope to help ya soon.
eTruckGear.com
  • 2 months later...
Body lifts for 14-15 models won't work on 16s due to the relocated bumper mounts. I'm still waiting for a company to step up and make a BL for a 2016.
    zibzer2
    zibzer2
  • Who's Online   5 Members, 1 Anonymous, 805 Guests (See full list)
