service stabilitrak, traction control, and abs lights on
Parked my truck last night with no error lights on cluster... used the remote start this morning to warm it up a bit before going to work... got in and started down the drive when I notice the dic is flashing between service stabilitrak and service traction control.. it also has abs light on... please help
Just an update... got out and killed truck at a store.. came back and Crunk truck up now no lights are on... confused now..
Any issue that can cause a misfire code like a fouled plug, failing injector, weak coil will trip these systems into a disable mode and are self resetting if all read ok at the next key cycle. As suggested, pull the codes.
Sent from my SCH-I545 using Tapatalk
I'll get a scan on the truck asap.. I thought maybe it was because it was started with remote start maybe?
  • 2 months later...
Did you ever get this fixed? If not it might be a simple and cheap fix, at least it was for me. I had the same lights coming on, shut the truck off for a couple minutes and the lights were off. It was happening more frequent so I had the ABS code read while it was on. Turned out to be a bad brake light switch.
probably a wheel speed sensor. mine started about a month ago when it was icy, my autocal didnt pick up any codes, so took it to the dealer and their reader found the left rear wheel speed sensor out. the wiring harness had a small break in it causing it short out, sometimes it would throw the lights and sometimes it wouldn't.
Had the same thing last week, No codes were read at the time. The temp was -28C outside and when it warmed up later in the day the lamps were fine (out) and all was normal. 2010 CC with 4.8 2WD.
