GM/Borla or Borla ATAK
geswek
This vid caused me to have a man crush on David Borla. If you suffer from ADD start clip at 5:50.
It compares the Touring, S-Type, and ATAK in a Camaro SS but great relative comparison back to back to back.
▶ 7:40
▶ 7:40
Geez looks like he gets off hearing his exhausts on cars... different in a good way.. attn david borla I made a kinda similar gm borla kit for a 6.2 silverado.. I'll let you drive it but if your gonna record yourself and talk about it.. I highly don't recommend wearing sweats... I'm just saying
^He does geek out, which is why their stuff is so damn good. They sell mufflers for a reason, much of which is for custom systems, as well as hack ins.
    President Roberto
    President Roberto
  • Who's Online   2 Members, 0 Anonymous, 230 Guests (See full list)
