2 hid kits neither work.
Doug64
You need the error cancelers to make them work correctly. You can find some plug and play ones on ebay or wherever you bought your hid kit.
What kit did you buy? I have a ddm kit, with cancelers and the battery harness. I've installed about 5 of these with no problems.
Make sure the polarity isn't reversed. Sometimes the plugs are backwards. They are on DDM tuning kits. BTW I've used DDM's as they are local to me, without incident. I've probably had three of their kits and no problem with the exception of bulb burnouts over time, maybe three bulbs in 10 years. Best buy IMHO. Good luck.
So matching red to red isn't necessarily important? I've used HIDS since 2004 and never had any problems like this.
I'll try reversing polarity as soon as I have time, and I'll report back. Thanks for the help.
Something else I just thought of, I've only connected the left-side hid for testing because of the whole air box removal pita. Would both sides need to be connected for them to power up?
I ran into the same issue when I installed hid's on my 2015 sierra. Ive installed hid's on 20+ vehicles wothout any issues yet I installed them properly on my sierra and they didn't fire up. I looked it up and saw something about reversed polarity so I flipped the connector arround and they worked. Your kit may be different than mine, but the stock headlight connector, where it plugs into the ballast connection is where I flipped it around. Hope that helps!
Nah. My bet is they are reversed polarity.
Thanks guys, I hope that's all the problem is. If not, I'll probably buy a kit from DDM. This is my first H11 install and I've noticed the plug has a shroud-like cover that the 9006 does not. Has this connector been a problem for anybody?
One thing I don't see mentioned is the plugs. If you are trying to use the OEM plug and go to the 9006 ballast or relay plug you may have issues. In my case the OEM plug wasn't long enough to make contact with the retrofitsource plugs resulting in no power to the ballast. Luckily I've done my fair share of retrofits so I have some extra no brand 9006 plugs/pins laying around so I made some adapters. Using alligator clips and wires you can test to see if this is your issue. I'm betting it is.
I've seen H11 to 9006 adapters on ebay, was considering them. I may get a pair, they're pretty inexpensive.
    Sothpaw27
    Sothpaw27
  • Who's Online   3 Members, 0 Anonymous, 439 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
